Vortec 357 SBC/ Monster Mike 700R4
Old Feb 25, 2018 | 11:08 AM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
Looking to see if there is anyone intrested in my drivetrain in my 88 Trans Am before I pull it. Motor was built 5 years ago and only has 10k on it along with trans.
Motor specs
3970010 1970-1980 Saginaw clock block 350 2 bolt main
Bored .040 over
Hypertenetic Aluminum pistons
Mallory cast rings
Stock rods
ARP rod/main bolts
Stock crank turned .010/.010
Edelbrock dual timing chain
Comp Cam XE285 Cam .508/.512 lift .262/.282 duration
Comp Cam beehive springs
7/16 screw in studs
Comp Cam 1.6 Aluminum roller rockers
Comp Cam pushrod guide plates
Comp Cam 1 piece hardened pushrods
Melling high pressure oil pump/pickup
98 Vortec 062 GM cylinder heads (machined, ported and polished by Jim Valeko from Spring Lake MI.)
Edelbrock Vortec ESP intake port matched to heads
MSD Ready to Run Distributor
Hooker Super Comp short headers
Holley 650cfm DP carb
Transmission
1988 700R4
Was torn down and rebuilt by Master GM trans tech.
B&M Shift kit
Corvette servo
Uograded 12 spline GM trans pump (factory pumps are 8 spline)
Flowed and dynoed valve body (line pressures increased)
Monster Mike drum/shell
Redline Clutches
TCI Street Demon 2400-2600 stall w/ lockup.
Stock imput/output shafts
Motor has ran great for many years, never smoked or ran low on oil pressure. Always ran Valvoline 20w50 oil. Transmission has never skipped a beat and shifts hard and fast. Always had external truck cooler on trans. Im going LS swap so this setup needs to go. Lots of time and money invested. Can hear motor run, and put car into gear. Rear axle is in need of rebuild so no test drives at this time. Price is 3000 obo for setup. Deposit required before setup gets pulled for buyer. Located in MI.
Old Mar 1, 2018 | 03:50 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
Re: Vortec 357 SBC/ Monster Mike 700R4
How much for engine shipped to Idaho
Old Mar 1, 2018 | 07:30 PM
Engine: Vortec 357
Ill sell engine for 1900 plus shipping. Ill get a rough quote on shipping tommrow. If you want more videos or info feel free to contact me by phone text/call 16169165020.
Old Apr 14, 2018 | 08:07 AM
2knight's Avatar
Car: 1982 Trans Am
Engine: 5.7 ls1
Transmission: 4l60e
If transmission & torque converter is available, how much to 58501?
bradley23150
23
Aug 31, 2010 12:55 PM
TADailyDriver
Members Firebirds
Apr 4, 2010 06:11 PM
Funtoy
Dec 27, 2009 06:45 PM
maniacc
Oct 10, 2002 10:35 AM
