[Sold] 90-92 tpi & 3.1L ecm
Old Apr 19, 2018 | 07:18 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
1227730 ecm no memcal $65 shipped in the states
Old Apr 27, 2018 | 01:20 PM
Engine: Lb9
Transmission: M20
Re: 90-92 tpi & 3.1L ecm
Bump
Old Apr 27, 2018 | 07:48 PM
91vertZ28's Avatar
Car: 1991 Camaro Z28 Convertible
Wondering if this would work with the 350 swap i messaged a while back about? I have a 91 z28 305 tpi 700r4. Would you be able to put a memcal into it and program it to be a replacement for a 350 swap? With the fan change you suggested and the antitheft delete that you also suggested? Id be able to keep my stock ECM for the 305 if i have any issues when smog time comes when i do the swap with the 350. All other things would be stock. Thanks again and hope to hear from you
Last edited by 91vertZ28; Apr 27, 2018 at 07:51 PM. Reason: Thought i sent a PM and didnt mean to put your name
Old Apr 27, 2018 | 07:54 PM
Engine: Lb9
Transmission: M20
I can program a v6 memcal to work as a v8. The bad is you loose the ability of having the ecm do knock retard.
Vats delete and lower the fans on and off is no biggie. The lowest I can do on the ecm with a memcal is $120 shipped.
Old May 4, 2018 | 06:22 PM
Engine: Lb9
Transmission: M20
Sold
ATCFLYBOY02
Feb 4, 2012 09:53 PM
DiabloWS6
Jan 22, 2011 10:27 PM
89irocz355
Dec 12, 2007 03:25 AM
The Project
Nov 10, 2007 08:09 AM
