installed a SK-700 &&&&
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
Welp, I"m at the point of pissed off now... I installed the SK700 and the following happened w/in 100Ft of the driveway:
1. Wont shift out of 1st
2. Blew ALL of the fluid out of the tranny (dunno from where though)
3. Gotta drive it to work monday... suggestions???
Engine: 4++,350 & 305 CIs
Re: installed a SK-700 &&&&
If you removed the servo, Im thinking, you blew the retaining ring out of the servo on the pass side of the trans due to it not being seated properly.
Car: 1988 Iroc-Z
Thats my 1st thought... I did everything with the car on the ground and I tried to take the servo out but it wasnt coming so I just put the retaining clip back in and left it. I got a corvette servo to go in it but since the cover was so close to the body, I didnt think the shaft would clear... Guess I'll be pulling the tranny out and going thru it again, A LOT more thoroughly... I'm thinking since it'll be out, I'll go ahead and do a full build since I found more metal in the pan than I'm comfortable with...
If I remember correctly if Drop the trans Xmember you can get the servo out.
gixxer92
Sep 1, 2015 04:32 PM
