[Sold] 89 tpi 305 Hypertech manual trans memcal
Old Jun 25, 2018 | 04:34 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
$105 shipped in the states works well
https://www.summitracing.com/parts/hyp-128951
Old Jun 25, 2018 | 04:45 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Re: 89 tpi 305 Hypertech manual trans memcal
I'd imagine that VATS is turned off on all of these Hypertech chips?
Old Jun 25, 2018 | 04:51 PM
Engine: Lb9
Transmission: M20
Vats is enabled but if someone wants I can reprogram it and disable it .
Old Jun 25, 2018 | 04:58 PM
chazman's Avatar
Axle/Gears: BW 3.45
I always wondered how that works on an aftermarket chip? Aren't there several VATS programs from the factory which work only with your particular ECM?
For example, I tried using the factory chip from one of my '89s in another '89 and VATS would let it start.
Old Jun 25, 2018 | 05:01 PM
Engine: Lb9
Transmission: M20
The vats is just a check box flag in the programming. Same frequency expected bye the ecm.
Some 88s had vats and the memcals would interchange with a 89. There are differences such as 9th injector and ac fan switch type. I don’t know why your memcal didn’t work as long as they were both the 165 ecm it should of worked.
Old Jun 29, 2018 | 12:49 PM
Benc1's Avatar
Car: 1989 Iroc convertible
Axle/Gears: 3.08 posi
Would you take 90?
Old Jun 29, 2018 | 12:52 PM
Engine: Lb9
Transmission: M20
If you cover the paypal fees or send as a gift.
I have good feedback here on itrader.
Send me a pm if your interested.
Old Jun 29, 2018 | 01:04 PM
Engine: Lb9
Transmission: M20
Sold
quick90rs
Mar 12, 2014 10:25 PM
Tuned Performance
Jan 12, 2014 03:13 AM
92TPI383
Nov 14, 2013 07:49 AM
