[Sold] [NJ] 406 SBC complete - bowtie block, AFR heads, miniram
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
Ran this motor in my 91 Firebird. Motor has about 50 passes on it and about 200 street miles. When on the street, it was run on 93 octane, at the track it was on VP110.
Bowtie block "1184" - 4 bolt non-splayed with 1 piece rear main seal adapter
AFR 210 (pre-eliminator) race ready heads. Springs changed 25 passes ago. Titanium retainers
Lunati forged Crank
Lunati 6.0" rods
JE Pistons - 11.7:1 4cc dome (originally was 8 but fly cut for valve relief)
Cloyes timing chain and cover
ATI Superdampner
CSR 153t flexplate
Moroso 6qt pan (fits stock k-member in fbody), moroso oil pump
TPIS miniram (material added to mate to 1206 intake gasket)
Edelbrock 1000cfm throttle body
66lb/hr Holley injectors (20 passes on them, no street miles)
Comp Cams solid roller cam 248/248 (cam card below)
Crane Gold Rockers and AFR stud girdle
Moroso Valve covers
Originally built by Truppi-Kling Performance in Green Brook, NJ
Freshened (heads,cam,pistons) by Dan Smith of DNS Performance in Camden NJ.
Best run in 3200lb car - 10.74 @ 127
Was run with Holley EFI. Can give the tune file with the engine.
Would make great street motor or bracket engine.
Asking $5500 or best offer
Lunati forged Crank
Lunati 6.0" rods
ATI Superdampner
CSR 153t flexplate
Moroso Valve covers
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
Re: 406 SBC complete - bowtie block
oh wow. nice I wasn't planning on doing my engine until december 2019, and I wont have the $ for it either...but this is cool.
also, I am in Roxbury NJ so not too far away either
subscribed
subscribed
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
This would make a good blueprint for you. In full street trim (with working AC) the car ran 11.60's
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
Well this is a kick in the *****.. If this was listed a few months ago I would have bought it. But I just had a 355 built. This is a deal..
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
Thanks. I originally was going to put AFR 220's on it and a bigger cam and try to go 9's but another SBC deal came up and I bought that instead.
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
Re: [NJ] 406 SBC complete - bowtie block, AFR heads, miniram
I would be interested in short/long block. Are the heads milled? What CC Are they?
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
Would consider splitting if deal on both came up.
heads are not milled and are 67cc chambers.
Car: 1987 IROC-Z
i sure do!!, but i will have to wait a year. looks like a great setup for someone to buy. best of luck
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
Weekly bump. Will separate intake and long block if I takers for both.
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Man, that is a nice setup. Very tempting. How much power did you make?
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
By the calculators given the weight and mph, it was around 515-525.
My original plan was to go with a larger cam and a set of AFR 220s and try to hit 9.99 with it. I ended up finding a good deal on a 434 so I am selling this one.
Its ts a solid foundation to run as is, or swap parts to go faster.
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
Would sell the long block for $4500 since I have several offers on the table for the intake
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
5k if its healthy is fair that takes some $ to build...seems everyone wants cheep buys crap off ebay then complains it dont turn a #.
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
I even have video of it and the time slips to back up the numbers.
if I didn’t purchase another engine, this would be in the car as we speak running pro e.t.
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
I’m interested. It’s more motor than I need, but the 406 in my Buick is dying. Let me talk to the wife about it. Would you be willing to meet part way....I live in central PA (north of Harrisburg)?
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Inquiring on a price for the heads sir.
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
Will not separate motor but will separate intake from long block. $4000 for long block.
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
lots of PMs, emails and interest, but in my shop it still resides......
you simply cannot build it for this price.
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
How much for the miniram? Thank you
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
If I could line up a buyer for the long block, I would sell the intake/injectors and throttle body
fire7rescue
Jan 26, 2016 08:44 AM
ZBRA
Sep 8, 2010 11:52 AM
Blown 346
247
Jun 26, 2010 08:52 AM
It'd go nice on my 421!
