[CA] Cleaning out my garage LOTS of parts
Old Mar 11, 2019 | 11:46 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
i can send pictures of any item through PM's too many to post here. shipping will be from 94553. let me know if you have any questions. thanks for looking. i added all the pics into a Flickr album.... https://www.flickr.com/gp/jonnyc127/5410V2
brand new energy suspension poly trans mount 3.1108R $30 shipped
brand new energy suspension front A arm poly bushings PN 3.3157R $40 shipped
power steering pump with lines $50 shipped
stock power steering fluid cooler mounts under radiator $50 shipped might be hard to ship due to size and metal lines.
stock 700r4 trans cross member with hardware $40 shipped
stock 10 bolt rear cover with bolts $25 shipped
oil pan bolt set with star washers. came with Jegs oil pan $5 shipped
52" serpentine belt barely used $15 shipped
4 stronger rear brake prop valve springs, 1 stock one $3 shipped each
comp cams crank sprocket for double roller timing chain $20 shipped
stock torque arm for 700r4 with hardware $50 plus actual shipping cost
Spectre braided engine hose sleeving 6 feet says for fuel line $10 shipped
5 pack edelbrock air horn gaskets PN 1499 $10 shipped
stock 1991 ignition coil $10 shipped
stock 700r4 2-4 servo $10 shipped
2 horns from 91 camaro $20 shipped for both
PROM from 1987 camaro 305 TPI 700r4. "4222 ABUN 8517" $50 shipped
ESC module from 91 305 TBI $40 shipped
header wrap probably 20 feet left $15 shipped
MAP sensor from 91 camaro 305 TBI $15 shipped
dual carb fuel line $25 shipped
thermostat housing with 2 ports $5 shipped
under dash light assembly $5 shipped
upper radiator hose bracket that goes near the alternator $5 shipped
91 TBI air cleaner hold down $3 shipped
manual choke cable $5 shipped
9 2.5" u-bolt exhaust clamps $10 shipped for all
Frame side stock motor mounts $40 shipped
B&M Holeshot 2400 RPM torque converter PN 70419 used for about 5K miles. no issues, got a bigger stall $250 shipped SOLD
front 36mm sway bar from 91 rs. $125 shipped SOLD
4 quart oil pan with rail hold downs $50 plus actual shipping costs SOLD
2.5 turn performance steering gear box 2 years old, no leaks, went to manual steering $100 plus actual shipping costs SOLD
K&N stub stack, slightly trimmed for clearance $25 shipped SOLD
2-2.5" exhaust cut-outs. scrapes near cut-out exit, still work fine. missing 1 wing-nut, replaced with a nut $25 shipped each sold
stock torque arm bushing mount with hardware $45 shipped SOLD
1991 camaro fender brace $10 shipped SOLD
3 bolt flange exhaust reducers 3"-2.5" $15 shipped SOLD
Passenger side (Smog, AC and tensioner) accessory bracket with tensioner missing tensioner pulley $60 plus actual shipping cost SOLD
Casper throttle enhancer PN CAS102107 $45 shipped SOLD
Old Mar 12, 2019 | 06:21 PM
jamesv's Avatar
Car: 1987 Chevrolet IROC-Z Camaro
Engine: LB9 > L98 5.7-liter V-8 TPI
Transmission: MD8 4-Speed Automatic MX0
Axle/Gears: GU5 3.23 G92
Re: Cleaning out my garage LOTS of parts
I'm in search of a complete set of a/c compressor mounting brackets for a 305 TPI engine. I'm not completely sure but i think there are around 7 or 8 pieces. The compressor is located on the driver side. Thanks in advance.
James
Old Mar 12, 2019 | 06:29 PM
James
i dont have any of those parts sorry. only have what is listed
Old Mar 12, 2019 | 06:48 PM
formula00ra's Avatar
Car: 1990 & 1991 Firebird Formula 350's
Engine: 350 ci
Transmission: T 5 & 700r4
Axle/Gears: 3:23 & 3:27
Casper throttle enhancer PN CAS102107 [b=left]$45 shipped. is this for tpi or tbi?[/b]
Old Mar 12, 2019 | 07:15 PM
Originally Posted by formula00ra
Casper throttle enhancer PN CAS102107 $45 shipped. is this for tpi or tbi?
this will fit engines with engine vin codes E, 7 or K. what is the 8th digit in your vin?
also as long as your TPS connector is round it will fit too.
Old Mar 15, 2019 | 11:11 PM
stub stack and B&M torque converter sold
Old Mar 16, 2019 | 06:10 AM
HellNauman's Avatar
Ill take the engine side motor mounts
Old Mar 16, 2019 | 09:05 AM
I pm'ed you.
Old Mar 19, 2019 | 10:10 PM
updated the list
Old Apr 11, 2019 | 02:54 PM
Bump
GMODUDE
Jun 5, 2010 10:59 PM
xpndbl3
Jul 30, 2006 06:36 PM
