Complete l98 intake fuel pump and Corvette computer
Old Jun 1, 2019 | 08:26 PM
lsturbo89's Avatar
Car: 1989 formula 350 turbo Firebird
Engine: 5.7L L98
Transmission: Stock
L98 intake with egr delete oversized Ford injectors and an adjustable regulator as well as an ecu from a 92 (iirc) Corvette that's chipped to handle turbo applications. Car was running when pulled but had bad rings been sitting a while so I figured I would just get rid of it. Asking 400. It's missing a wiring harness though. So you'll need to supply your own. Otherwise everything should be 100% functional.
Old Jun 1, 2019 | 08:31 PM
lsturbo89's Avatar
Engine: 5.7L L98
Transmission: Stock
Re: Complete l98 intake fuel pump and Corvette computer
Just a side note, the pump is new(ish) but the sender was broken so it was rewired and had a couple holes drilled into the top so the wires could be ran. I didn't know what I was doing when I had this car. I did solder the ground to the sending unit correctly and it does work but you might want to use your original sending unit, if possible..
knute_gis
Sep 6, 2016 02:54 AM
kg1922001
May 24, 2013 01:42 PM
kowboy59
Nov 7, 2011 09:36 PM
IrocZ'85
Aug 15, 2011 08:50 AM
