HOOKER shorty headers, titanium ceramic coated, y-pipe
Old Dec 9, 2019 | 01:42 PM
2knight's Avatar
Car: 1982 Trans Am
Engine: 5.7 ls1
Transmission: 4l60e
I am getting rid of my small block so I want to sell these Hooker headers and y pipe. These fit perfect and was able to install both from the top of engine & both have have only around 600 miles on them but the headers were just titanium ceramic coated and only 150 miles on new coating. This is a higher temp coating than what comes from factory, I had them recoated because the original coating couldn't stand up to cam break in. I have a matching y pipe and cat delete. The y pipe is 2.5" diameter and is same brand. As you can see in the summit photos these 2 pieces are not cheap so I'm looking to get 400+ shipping. I will include header bolts and custom made wrench to make them easier to tighten. I used remflex gaskets at collectors and head and had no problems with leaks. headers have a few scratches from installing and removing but otherwise good condition. y-pipe has heat wrap where it passes under oil pan installed and both pieces were welded together so if I had to ship them I would cut in half at connection to get it boxed up, then would have to be re welded upon installation.
Old Dec 11, 2019 | 08:51 AM
KOdc's Avatar
Car: 1988 Camaro IROC-Z
Axle/Gears: 9 Bolt
Re: HOOKER shorty headers, titanium ceramic coated, y-pipe
Where are you located? Thanks
Old Dec 11, 2019 | 11:01 AM
2knight's Avatar
Car: 1982 Trans Am
Engine: 5.7 ls1
Transmission: 4l60e
North Dakota
Old Mar 9, 2020 | 08:55 PM
2knight's Avatar
Car: 1982 Trans Am
Engine: 5.7 ls1
Transmission: 4l60e
THESE ARE SOLD!! Thanks Tidan.
the_hamturdler
Dec 4, 2014 07:16 PM
kkingsrulee
Mar 18, 2009 10:02 PM
ad356
Nov 30, 2006 01:44 AM
BowtieFever
Aug 14, 2002 11:07 PM
