[IA] EFIConnection 58/4X Small Block Chevy conversion parts
Old Dec 29, 2019 | 12:19 PM
gixxer92's Avatar
Car: 1986 IROC, 2017 Silverado
Engine: 7.0L, 6.2L
Transmission: Tremec Magnum, 8L80
Axle/Gears: 3:23, 3:55
These parts were used for approximately 50 miles before the ATK junk short block (Decked wrong from them) decided to impact my intake valve, break it and grenade the #3 cylinder. Putting a LY6 6.0L in my truck and don't need the parts any longer since my vehicle inventory is all LS now.
Asking $1000 for this as a whole and will consider reasonable offer's close to this price. I'd like to sell as a kit but if I can get buyer's for parts I will break it apart.
This kit will allow you to run a Drive By wire System (selling Edelbrock Pro-Flo Intake config separate from this add). This is done by using a GM ECU or Holley TerminatorX or Dominator.
120-00139, $870
Designed for SBC w/ Roller Cam, step nose and one piece seal engine
The above part encompasses the following 4 part numbers.
Billet Timing Cover - 120-00092 - $425
Double Roller Timing Chain w/ 4X on Cam gear 120-00069 - $240
Crank Position Sensor - 110-00005 - $45
Cam Position Sensor - 110-00052 - $45
Two Resonant Knock Sensor mounts - 120-00053 - Qty 2, $24 per
Two Resonant Knock Sensors - Qty 2, $20 per
Oil Pump Drive - Mallory 29003 - $150
120-00072 - Single Coil Pack mounts for Center Bolt valve Covers with bolt kit ($211)
EFI Connection 58X 4X Small Block Chevy Kit
Old Dec 30, 2019 | 05:48 AM
rgauder's Avatar
Car: 1987 Trans Am
Re: EFIConnection 58/4X Small Block Chevy conversion parts
sub'd
Old Dec 30, 2019 | 11:31 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Pm sent
IROCThe5.7L
Jul 9, 2011 11:08 AM
va454ss
22
Aug 27, 2007 11:31 PM
smokefan
Jan 8, 2005 01:17 PM
Paul Riccioli Jr
Apr 19, 2001 08:47 PM
