[CA] 3rd Gen Suspension Parts, SBC Parts, LS1 Parts
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
I'm cleaning out storage and my garage of parts. A few years back I had abandoned my 3rd gen project car and all this stuff has just been sitting around. Need to get rid of it. Looking to make deals and get things out of here, accepting reasonable offers on all and everything. All prices will include shipping, so please take that into account on offers or posted prices. I will consider moving on price if you buy multiple items that can be shipped together. I am located in the East Bay Area, CA if you are local and want to pick up parts.
Hawk HPS LS1 Front Brake Pads: $65
New in Box. HB249F.575, HPS
Hawk HPS LS1 Rear Brake Pads: $50
New in Box. HB250F.653, HPS
Summit 8mm Universal Mag Core Ignition Wire Set: $35
New in Box. 8MM Silicone Wires w/ Crimper and Terminals/Boots, For later HEI style. Blue.
SUM-G825
LS1 Stock Injectors: $75
New, were SLP LS1 Removals. Flow 25.7 lb/hr at 3 Bar. Cut grove all around for use with modified clips, also included. Missing 4 o-rings. Had them flow tested, data here.
P/N: GM - 12561462, Bosch - 280 155 931
______
SOLD:
Spohn Tubular A-Arms: -SOLD-
New. Built w/ Stock Style Spring Perches, Poly Bushings and Ball Joints Included. I have the mounting hardware as well to include.
SUM-G825
______
SOLD:
Re: 3rd Gen Suspension Parts, SBC Parts, LS1 Parts
______
SOLD:
Energy Suspension Poly SBC Engine Mounts: -SOLD-
New in Box. Inserts fit in your stock clam shells. P/N 3.1116G
ARP Motor Mount Hardware: -SOLD-
New in Packaging. P/N 130-3105
Spohn Wonder Bar, Steering Brace: -SOLD-
New, Black. Does not include mounting hardware.
Adjustable Camber/Caster Plates: -SOLD-
New. Not sure who made these. Spherical upper bushing. Adjustable for both Camber and Caster.
SOLD:
_______
SOLD:
Earl's Stainless Brake Lines: -SOLD-
New. Bought for my '87 Firebird to fit LS1 Brakes. Not sure on part number (I think they're Earl's 28A520), do your research to confirm with picture.
AC-Delco 170* T-Stat: -SOLD-
New in Box. 170*. AC-Delco 131-84/GM 10220957
https://i.ibb.co/HXR6Z0p/Tstat1.jpg
GM 2-Bar MAP Sensor: -SOLD-
2 Bar Map, friend gave it to me, was working when pulled. GM P/N 12569241
Gatorback Belts: -SOLD-
New, 15335 and 4050420
Master Ride Chassis Tie Rod Ends, Idler Arm, Tie Rod Sleeves: -SOLD-
New Parts, older NAPA Brand, used to be premium parts. Included: 2 x Inner (ES2227L), 2 x Outer (ES2226R), Idler Arm (18832) and Coleman Racing Solid Sleeves w/ Nuts.
SOLD:
Car: 1992 Z28 1991 RS
Engine: LB9 LO3
Transmission: 5 speeds
I’ll take the ARP 130-3105 motor mount hardware. PM your PayPal and I’ll send the money over.
Car: 1989 Camaro, 1989 Firebird
Engine: 5.0 TPI, 5.7 TPI
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.23
Interested in the wonder bar. Pm your PayPal please.
Transmission: Pro-built 700R4
Would you do $20 for the MAP sensor and t-stat to 93021?
Will take if available
Master Ride Chassis Tie Rod Ends, Idler Arm, Tie Rod Sleeves: $100
Energy Suspension Poly SBC Engine Mounts: $45
AC-Delco 170* T-Stat: $8
GM 2-Bar MAP Sensor: $15
Gatorback Belts: $11 Each, $20 for Both
Earl's Stainless Brake Lines: $50
Please confirm & send PayPal
information.
Zip 92583
Thanks,
information.
Zip 92583
Thanks,
information.
Zip 92583
Thanks,
information.
Zip 92583
Thanks,
cpears
22
Feb 22, 2008 11:59 PM
