[FL] Champion 3 Row Alum Radiator CC951 - $75
Old 04-07-2020, 08:15 PM
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI + some bits
Bought this two years ago, used a couple hundred miles. Taking it in and out of the car a few times as I did various projects. Somehow I put a hole in one tube. I tried to aluminum braze it 10 times and I can't get it to seal so I bought another radiator out of frustration. Also one of the dual plastic original fans scraped away parts of a couple other tubes but those are not leaking tho they look like they should be.
I figure if you know how to braze aluminum this should be a cheap way to get a great radiator for around $100 with shipping depending on where you live which is less than half the cost of a new one.
I have some high def pics I can post so you can see for yourself. When I get the new rad I will use the box to ship to you so it will be safe.
Cheers.
Old 04-08-2020, 03:13 PM
TallTim's Avatar
Re: Champion 3 Row Alum Radiator CC951 - $75
Here's the pics.
92zcamaroperson
44
06-15-2008 11:33 AM
scott92RS
09-03-2004 08:31 PM
david auster
03-08-2003 06:18 PM
Quick Reply: [FL] Champion 3 Row Alum Radiator CC951 - $75
