have a 52 mm Holley Throttlebody for sale, will fit an 85-88.
It is used, sold as is. You will need a tps and an iac.
Asking $225 shipped lower 48.
Matt
Reason: SOLD
Shipping to the Netherlands possible? No broken iac housing bolts?
Wouldn’t be an issue. I have shipped parts to Australia in the past. IAC bolt hole are fine, none stripped. I used this on my 350 and then again on my 383. I also have a 383 anodized plate to replace the Holley one if you want it, I’ll put it in the box too. I’ll pm you.
Matt
It will with a throttle cable change to 85-88. You also need a hole made into the plenum for the iac to get vacuum. Making a 3/8 hole in the plenum would work.
