TPI setup-Lingenfelter/Accel Runners w/ base & plenum
Selling my TPI setup b/c I've changed projects. Runners are Lingenfelter/Accel with heavily ported and port-matched stock TPI base and plenum originally done by John Lingenfelter himself. Last year I had it professionally bead blasted, hot tanked and then I applied 3 coats of Dupli-Color Ceramic Aluminum Engine Enamel followed by 3 coats of Clear. This setup came off SLOW305's stock L98 in his '82 CP class camaro. I bought his entire long block setup a couple of years ago for my '91 Firebird but have since moved onto a C5 for autoX and plan to use the L98 with an HSR in my '70 Skylark build. Article below is of his car with this TPI setup from a 1990 Hot Rod Magazine article. On a bone stock L98 with this intake, headers and a MegaSquirt, SLOW305 squeezed out 256/355 to the wheels on a Dynojet and ran a 13.55 @ 101 on street tires. Dyno graph is also posted below. Asking $750 plus the ride. Each piece will be individually wrapped and shipment will be fully insured and shipped via UPS Ground.
Reason: SOLD
Re: TPI setup-Lingenfelter/Accel Runners w/ base & plenum
Soooo..... this has egr? how about 9th injector. Sorry Been out of the game for awhile. Trying to refresh my memory. Looking to replace stock tpi on a 1988 l98 ta.
No worries! Yes, still has EGR and can accommodate a 9th injector (there’s currently a removable plug in runner where 9th injector would go).
And just to double-check that I'm not forgetting anything this will fit on non Vortec center bolt stock heads?
and off the subject is there a setting on here so I can be notified when I get a message? Thanks
Sending you a PM on shipping.
Yes, this will fit standard, non-vortec heads.
When logged in, go to user control panel and you can adjust your settings there. Also, when replying to a post, below the “submit reply” button, there is “Additional Options” and you can select notification type.
