This manifold and pair of tubes is off of a 1992 L98 Camaro. The manifold is 100% stock and has not had any porting done to it. I can leave off the dented oil splash shield if you'd like (that shield was from a junkyard manifold). The tubes were opened up a little bit at the ends to match the gaskets. Two little dings in the tubes near where the bolts go in, aside from that they just need to be cleaned. Looking for $45 for the manifold and $50 for the tubes. Located in West Nyack, NY
