Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
hybrid big block efi manifold
Old Jul 31, 2015 | 09:56 PM
daniel92345z28's Avatar
Car: 82 camaro z28
Engine: gen 6 454 carburated and cammed
Transmission: ls1 t56 trans
Axle/Gears: currie f9 with 3.70 gears
making a bbc efi manifold for my third gen camaro. using weiand base manifold used a bridge port to mill some off the top for hood clearance .made a adapter plate and used the holley lsx top plenum 102mm opening still working on it just need to weld it and do some port work and done. here are some pics.
Old Jul 31, 2015 | 09:59 PM
Car: 82 camaro z28
Re: hybrid big block efi manifold
Old Jul 15, 2016 | 02:16 PM
irocman7's Avatar
Car: 89' Sunset Metallic Orange Iroc-Z
Engine: Forged 383
Transmission: TR6060
Axle/Gears: 4.11 9 inch
Sorry to drag this one from the dead, and a long shot on getting a response. I just saw this post, I am doing a Gen VI 496 swap on my car, and am having a hard time finding a reasonable mpfi intake for oval ports. How did this turn out? Cool idea!
Old Jul 19, 2016 | 10:00 PM
Car: 82 camaro z28
still not done with the manifold but i did do some porting on the runners and port match to gasket .gonna be using holley dominator ecu or the aem infinity for my engine
Old Jul 19, 2016 | 10:07 PM
Car: 82 camaro z28
converting from carburated over to efi but im gonna try to make power over a single plane,edelbrock victor jr set that im currently running,
lets hope it makes more than this 509rwhp and 479 rwtq at 7000 rpm
Old Jul 19, 2016 | 11:26 PM
irocman7's Avatar
Engine: Forged 383
Awesome ingenuity, that LS upper is pretty pricey though right? I wonder if I could modify a Stealthram upper, or build something similar. I am anxious to see your results.
I worked with Holley HP on another project, it is user friendly and very powerful. I was really impressed, and I know Dominator is a step up. I am going to work with the 411 a little more, just because I like to complicate things.
What are the specs on the motor?
Old Jul 19, 2016 | 11:35 PM
Car: 82 camaro z28
gen 6 454 bored .030 over
wiseco forged piston 11 to 1 compresion
6.385 h beam wiseco k1 rods
502 forged crank with 4 inch stroke
comp cam solid roller 260/268 @.050 duatation .714/.714 lift
bowtie bbc heads 325 intake runner mild porting
jessel shaft rockers.
t56-currie 9 inch 3.70 gear
street car lol
Old Jul 20, 2016 | 09:53 AM
irocman7's Avatar
Engine: Forged 383
Oh yea, that baby should have a lot more in her 11to1 solid roller.
Sorry to keep askin, you are running a setup very close to what I am planning. I am currently running an LT-1 t56, and am trying to figure out how it is going to mount up. What flywheel did you use with yours (I know you are on a ls1 t56).
Some stuff I have read is the LT-1 flywheel will actually mount up to the gen vi crank.
Old Jul 20, 2016 | 11:04 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Interesting intake but i wonder how well it would compare to the edelbrock tunnel rams or single plane victor efi's. Looks identical to the sbc stealth ram base and those only could support so much power before the runner size was a restriction
Old Jul 20, 2016 | 09:34 PM
Car: 82 camaro z28
i was running the ls1 t56 but the found a viper t56 put that in instead.i had the fly wheel made by a local shop that specializes in flywheels.billet steel using the 153t style stage 3 competition clucth .howe throwout bearing.t56 adapter plate with sbc bell housing. will be upgrading to a sfi scatter sheild soon because i like having feet
Old Jul 20, 2016 | 09:38 PM
Car: 82 camaro z28
here is the link to when i did the t56 swap
https://www.thirdgen.org/forums/tran...trans-bbc.html
Old Dec 7, 2016 | 03:53 PM
Bowtie468's Avatar
Very nice fab work.
Old Dec 11, 2016 | 10:13 PM
Car: 82 camaro z28
Thanks ,here is a quick update on what ive done lately.bought a holley 105mm throttle body hoping to make it work with the 102 holley plenum with some minor port matching.i dont think it gonna work -_- .so im just gonna have to buy the 105 version and sell the 102.getting closer to finishing
Old Dec 13, 2016 | 05:06 AM
83 Crossfire TA's Avatar
There is no way that opening is 2mm smaller, maybe something like 90mm if the throttle body is 105mm. It wouldn't be that big a deal to open that one up to match the throttle body assuming it bolts on and there is enough metal there, by hand or on a mill if you have access to a bridgeport (it would be more work to fixture it on the mill then the cutting).
Why didn't you just bolt it to the top of the manifold since it already has bolt holes?
Didn't the original base have more shape to it, I'd be worried about airflow/distribution issues with that flat bottom.
Old Feb 11, 2017 | 09:35 PM
Car: 82 camaro z28
got some more progress coming along ,also finally pulled the trigger on the dominator efi and holley universal harness.
the ecu is bigger than i expected was gonna mount it under the dash but change my mind
Old Feb 12, 2017 | 08:13 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
coming along very nice!
Old Feb 27, 2017 | 02:17 PM
irocman7's Avatar
Engine: Forged 383
I worked with the Holley HP EFI, very nice setup, and I know the Dominator has tons of extra features. Please keep us updated on your progress I am really interested.
Old Jul 10, 2017 | 04:56 PM
Car: 82 camaro z28
finally got the bbc to fire up
took longer than what i was thinking
also installed a borla cat back exhuast
installalled v bands
tig welded the whole exhuast sytem
aem fuel pump 50-1005 used -8 fuel line for fuel system
Old Jul 10, 2017 | 04:57 PM
Car: 82 camaro z28
still need a new hood that will work with new set up and still need to buy some radiator fans.happy so far with efi
hope to have dyno number soon and some 1/4 mile times as soon as it cool down in CA.
Old Jul 10, 2017 | 05:05 PM
Car: 82 camaro z28
Old Jul 10, 2017 | 08:46 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Looks awesome. I want that intake lol. Gets me excited for my 555 bbc build.
Old Jul 11, 2017 | 02:51 PM
Car: 82 camaro z28
some more pics of exhaust and finished wired engine bay. i still need to make a intake and other minor stuff
Old Jul 14, 2017 | 07:11 PM
cam406406's Avatar
Car: 1989 TA
Engine: 406
Transmission: 400
Axle/Gears: 9 inch
Does it run yet. How that intake work out
Old Jul 15, 2017 | 04:48 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
very nice
Old Jul 26, 2017 | 10:46 PM
Car: 82 camaro z28
yeah i got it running already but wont have any dyno numbers yet maybe in one month.so far throttle response is a lot quicker , no more idle rich smell and it seems to rev faster sounds a lot better too
Old Nov 19, 2017 | 01:11 PM
Car: 82 camaro z28
got dyno number from the the carb set up and the new efi set up.
i was happy the results i picked up a little up top lost a little down low.
also went to the drag strip and was faster than before!!
Attached Thumbnails hybrid big block efi manifold-imag0751.jpg   hybrid big block efi manifold-imag0752.jpg
Old Nov 19, 2017 | 01:25 PM
Car: 82 camaro z28
also have the time slip from the track @ fontana dragway
i was the left lane
Jorlain
Oct 8, 2015 01:57 AM
86CamaroDan
Sep 29, 2015 10:08 PM
New2Chevy
Sep 28, 2015 12:35 AM
middian
Sep 5, 2015 01:42 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
