Factory electric fan from my 1985 TPI IROC, may also fit other 3rd gen models. FAN was recently installed and working. Cooling system was upgraded so I no longer need this.
Asking $50 plus shipping
Love reviving old threads. Anyway, the inconsistent blade spacing is to reduce noise (in theory). A blade passing over an object will make a noise. If the blades are evenly spaced and rotating at a consistent speed, you'll end up with effectively constructive interference between the blade noises, increasing the effective volume. By making the blade spacing inconsistent, constructive interference is no longer as probable. Fun stuff!
