2 throttle bodies, 1 stock, 1 52mm holley. Throttle body coolant passages blocked. IAC motor and throttle position included.
Stock Main plenum polished top, EGR walls behind throttle body removed, runner passages matched to SLP sunglasses shape runners. Plastic distributor cover included. IAT sensor included.
2 sets of runners, 1 stock (pretty beat up but functional), 1 SLP ported set with 9th injector passage blocked.
Stock Lower manifold ported and gasket matched to FelPro 1205 gaskets with functional EGR valve.
Stock fuel rails, with BBS adjustable fuel pressure regulator, set of 19lbs/hr injectors.
Set of TPIS big mouth gaskets included. Holley 52mm Throttle body Holley 52mm part numbers TPI parts
Whole setup $500 OBO.
I have some other posts (or soon will) with some interior parts (88 trans am) along with the serpentine setup that went with the above. Nice alternator, starter, distributor, autoprom gear, and other parts.
Reason: sold
