[OH] TPI intake polished
Old May 13, 2012 | 04:07 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
TPI intake polished
This is a tuned port injection system for an 85-92 Firebird or Camaro. The base is the early manifold style but the runners do not have the provision for the 9th injector. The plenum has been ported to fit up to a 58mm throttle body. The runners and plenum were sanded smooth and polished for a new look. The throttle body is a factory 48mm and comes with the IAC and TPS sensors. The fuel rail is modified for a rear inlet and return with 6an fittings. The fuel pressure regulator is a BBK adjustable unit. Also comes with an extra set of injectors, throttle body air foil, EGR valve, and new Holley map sensor. Can arrange to be shipped if needed. Asking $300.
Old Jun 4, 2012 | 07:20 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Re: TPI intake polished
Bump, lowered price
Old Jul 15, 2012 | 12:00 PM
kevinlcook95's Avatar
Car: 89 GTA 5.7 t-tops/07 GMC Sierra SLT
Engine: 350 5.7 liter/ 6.0 Vortec Max
Transmission: built 700r4,shift kit,cvtte servo
Axle/Gears: Stock B/W 7.5 323 gears
How much for the BBK pressure regulator and the injectors shipped to 31909 GA?
Old Jul 17, 2012 | 03:19 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
$50. Not sure what size the green injectors are though.
Old Jul 18, 2012 | 02:15 AM
Jeffs82TA's Avatar
I'm interested in the plenum and runners if you will separate.
Old Jul 18, 2012 | 07:04 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
$140 shipped.
Old Sep 18, 2012 | 11:02 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Still for sale
Old Sep 18, 2012 | 02:24 PM
karistanker's Avatar
Car: 89 Sport Coupe Vert (IROC-Z clone)
Engine: 383 Stroker TPI
Axle/Gears: 2.73 (3.73's awaiting install)
Bump for a good priced unit!!! Oh and a shootout to Cleveland, I used to live on west 25th!
1992rs/ss
Jan 31, 2025 05:10 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
theurge
Aug 21, 2015 12:46 PM
kah992
Aug 19, 2015 02:55 PM
Sanjay
Aug 12, 2015 03:41 PM
