[IA] SOLD - $450 - Detroit Speed (DSE) Caster Camber Plate Kit 82-92 Camaro/Firebird
Old 10-03-2021, 07:16 AM
cmdtech's Avatar
Detroit Speed DSE Caster Camber Plate Kit 82-92 Camaro
https://www.detroitspeed.com/caster-...irebird-030330
Installed and aligned then removed. Zero miles on them. These were used for mock up purposes.
The Detroit Speed Caster/Camber Plate Kit is a direct bolt-on kit that allows precise camber and caster adjustments at the strut tower. The kit features Speed-LIGN technology that allows consistent and precise movements without any worry of unwanted movement after the adjustment is made. The camber and caster can be adjusted independent of each other and allows increased adjustment range over stock. The kit uses an aircraft-grade monoball for strut shaft attachment for smooth, precise articulation throughout suspension travel.
Note: The Caster/Camber Plate Kit also includes the Detroit Speed, Inc. Strut Mount Retainer Kit. It is a direct bolt-in replacement for the 1987-92 vehicles that will come electroplated with new hardware. They can also be used to replace the strut mount retainers on 1982-86 vehicles by slotting one hole in the strut tower.
https://www.detroitspeed.com/img/pro...r%20Plates.pdf
https://www.detroitspeed.com/img/pro...20Retainer.pdf
http://www.superchevy.com/how-to/cha...ension-upgrade
Will trade (+/- cash) for:
Looking for a 00-02 Camaro, ls1/auto parts car
Steering column with tilt, cruise, delay wipers for manual trans
00-02 HVAC controls, wiring, vacuum lines. I also need misc AC parts.
Need complete windshield wiper setup from 98-02 Camaro
3rd gen parts:
3rd gen LS swapped CAI (behind drivers headlight)
Remote battery mount
86-90 K-member, if it's already notched out for AC that's a plus
cmdtech is offline
Old 10-12-2021, 08:36 PM
z28cp's Avatar
Re: SOLD - $450 - Detroit Speed (DSE) Caster Camber Plate Kit 82-92 Camaro/Firebird
Well, guess I missed that deal 😖
Can I ask why you decided not to use them?
Thanks!
z28cp is offline
Old 10-15-2021, 08:15 PM
cmdtech's Avatar
I had two sets. One I used for mocking up my build and the other was new in box for another build which I'm no longer building. The shop installed the new set instead of reinstalling the ones we used for mockups. I'm in the process of getting ready to sell the LS1/M6 build (pictured) and I'm selling the set I used for mocking up.
cmdtech is offline
QwkTrip
03-18-2023 12:22 PM
1Aauto
Sponsored Vendors
10-17-2019 12:57 PM
1Aauto
Sponsored Vendors
10-07-2019 03:21 PM
cohnrunner
Aftermarket Vendor Review
08-28-2017 09:17 AM
1985blktransam
08-20-2012 10:26 AM
Quick Reply: [IA] SOLD - $450 - Detroit Speed (DSE) Caster Camber Plate Kit 82-92 Camaro/Firebird
