[CO] Miscellaneous Parts - garage cleanout
Old 03-25-2022, 10:04 AM
BovineZro's Avatar
Car: '91 Camaro Z28
Engine: L31 5.7
Axle/Gears: 10 bolt, 3.73
Summer is just around the corner and it's time to make some room in the garage so I can actually work on the car! Most of this stuff is probably destined for the junk heap but I figured I'd give the folks here a shot at it first. Priced as marked plus actual shipping charges (unless you choose to pick up).
~14" no-brand air cleaner. Confirmed to fit under a '91 Camaro hood. Filter is old but usable (or save some money on shipping and I'll just toss the filter). $10 plus shipping.
OEM transmission crossmember from '91 Camaro. Should work with both 700R4 and T5. $10 plus shipping.
L31 (Vortec) timing cover. Installed but never run (gasket should still be good). Dirt and grime included. $5 plus shipping.
Old 03-25-2022, 10:12 AM
BovineZro's Avatar
Car: '91 Camaro Z28
Engine: L31 5.7
Re: Miscellaneous Parts - garage cleanout
Second page of items!
Oil filter mount, used. Might clean up okay. $5 plus shipping or free if you buy anything else.
OEM ten bolt cover. Surface rust, but otherwise in good shape. $5 plus shipping.
Fuel tank straps. Left one is a little bent out of shape but it should bend back fine. $15 plus shipping for the set (shipping will be a bit pricey on these)
Strut tower braces. $5 plus shipping or free if you buy the strut tower mounts (listed below).
Fuel pump block off plate. $5 plus shipping or free if you buy anything else. No, I won't clean it.
"Classic" SBC water neck, chrome. $5 plus shipping or free if you buy anything else.
L31 (Vortec) reluctor wheel. $5 plus shipping or free if you buy anything else.
OEM strut tower mounts. $15 for the pair plus shipping.
Old 03-25-2022, 10:49 AM
Edsiroc's Avatar
Car: 1989 Camaro, 1989 Firebird
Engine: 5.0 TPI, 5.7 TPI
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.23
I’ll take the Rear disc conversion brackets for LT1/1LE calipers with 12" rotors (from Flynbye).
Old 03-25-2022, 10:58 AM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
I'll take the strut tower braces.
Old 03-25-2022, 04:47 PM
BovineZro's Avatar
Car: '91 Camaro Z28
Engine: L31 5.7
Saw your message, I've replied in DM.
Old 03-25-2022, 04:52 PM
BovineZro's Avatar
Car: '91 Camaro Z28
Engine: L31 5.7
DM sent!
Old 03-25-2022, 06:51 PM
scarbucket's Avatar
Car: 1987 Firebird Formula
Engine: 305 Tpi
Transmission: Borg Warner 5 spd
Axle/Gears: 3:73
Interested in torque arm external mount. lets figure out what its gonna cost to ship it lol
Old 03-25-2022, 08:44 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
PM sent.
iroc_you's Avatar
Car: 1984 z28 h.o l69
Engine: 355
Transmission: t5
Axle/Gears: 3.73 posi
What would shipping cost to 26147 on the umi crossmember.
Old 03-25-2022, 09:14 PM
BovineZro's Avatar
Car: '91 Camaro Z28
Engine: L31 5.7
I've got three folks interested in the crossmember, so I'm marking that sold for now. PMs have been sent!
Old 03-26-2022, 09:57 AM
grnmachine's Avatar
Car: 92 RS Heritage Edition
Engine: LG4 305
Axle/Gears: 3.73 10 bolt posi
PM sent
Old 03-26-2022, 11:45 AM
BovineZro's Avatar
Car: '91 Camaro Z28
Engine: L31 5.7
Originally Posted by grnmachine
PM sent
Responded
Old 04-04-2022, 04:52 PM
BovineZro's Avatar
Car: '91 Camaro Z28
Engine: L31 5.7
TTT
Make me an offer on any of this stuff, it's going to the dump at the end of the month!
usafirebird
03-15-2017 02:51 PM
armybyrd
03-21-2016 02:29 PM
Thurman_Merman
04-21-2015 10:20 AM
EDS01SS
01-22-2009 02:41 PM
dpmalibu
04-02-2008 07:20 PM
Quick Reply: [CO] Miscellaneous Parts - garage cleanout
