[NC] Third Gen Parts - Garage Cleanout
Old Mar 12, 2023 | 06:37 PM
89RScamaroBlue's Avatar
Want a title? Post!
Hello,
I have a lot of third gen parts for sale.
Located in Mooresville, NC
Free Local Pickup - Can ship also.
Message for pictures or price.
Willing to make deals to clean my garage out.82-92 Third Gen Camaro Parts For Sale
Dash (Not the dash pad, but the dash from an 89 RS) Very Nice Condition! $300
85-92 Camaro/Firebird Upper Single Electric Fan Shroud Style 2, 28” Long, Hose on LS/Drivers side $75
Lower Single Fan Electric Shroud $35
Wheels Set of 4 (89 Camaro Grey) $200
Fuel Neck Shroud $15
F Headlight Harness 82-92 Camaro Firebird $75
R Taillight Harness 82-92 Camaro Firebird $75
LF Fender Marker Light $10
Right Rear Bumper Bracket
Rear Bumper Impact Bar & Absorber Pad $200
Rear Tag Bracket $25
LS fender brace
Hood Latch $20
Fuel Door 82-92
Rear End Differential Assembly - 2.73 single drum brake $350
Torque Arm $75
Bump Stops Used, pair $40
Transmission crossmember 82-92 T5/700R4 $75
Rear Brake Backing Plates Dorman 3867, Replaces GM 10013525, Replaces GM 10013524 $40 pair
Rear Sway Bar Bushing kit AC Delco 45G0013 GM 88912162, Precision $20
Delco Knock sensor 213_325, GM 10456287 $10
Lower A Frames $125
Front Sway Bar $75
Rear Sway Bar $50
Dash Harness $150
Shifter Assy $50
Spindles $250
Master Cylinder Assy $40
Brake Booster $60
Front Springs $40 pair
Rear Springs $25 pair
Blower Motor $20
Fuel Lines- Used
Brake Lines - Used
Brake Lines - New $150 Stainless Steel kit for drum brake rear
Track Bar
Lateral Rear Brace
Steering Box
Gas Tank Straps
Hood Braces
Struts
Strut Tower Supports
Starter - Automatic Trans
Rotor Guards
Suspension Links - Rear End
Front bumper Support Brace
Hood Latch
LR Taillight
Automatic Transmission Flywheel
Flywheel Shield Guard
RV17YC Spark plugs x 8
Lower Air Dam deflector
Grill Bezel
Exhaust Shields - Underbody
E brake handle & cable
Throttle pedal assy
Brake Booster
Vacuum Canister $10
Engine Mounts
Alternator
Gray Arm Rests
Automatic Brake pedal Assy
WS wiper motor
Heater core box
Copper Heater core
Automatic Trans Selector Assy & cable
Door sill panels - grey
Grey Carpet - trunk area
Grey Interior plastic set
RF fender $75
RS Door - lower outside piece
Dash Assy - not dash pad
Seat Belts - Grey
AC Condensor & Shroud Assy
Interior main Harnesses
Last edited by 89RScamaroBlue; Mar 13, 2023 at 11:29 AM. Reason: Added prices & pics
Old Mar 12, 2023 | 09:57 PM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
Re: Third Gen Parts - Garage Cleanout
Can you post pics. I believe prices are required.
Feel free to pm me here or text me at 512 947-5537 or email me at topduarte@yahoo.com
Manny
Old Mar 26, 2023 | 12:52 PM
Edsiroc's Avatar
Car: 1989 Camaro, 1989 Firebird
Engine: 5.0 TPI, 5.7 TPI
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.23
Would you happen to have the front brake hose brackets that bolt to the front struts?
Old Mar 26, 2023 | 08:06 PM
Want a title? Post!
I am pretty sure that I do.
I’ll confirm and let you know.
Old Mar 26, 2023 | 09:32 PM
Edsiroc's Avatar
You can pm me. Thanks!
Old Mar 27, 2023 | 11:09 AM
sodak's Avatar
Car: 1985 iroc
Engine: 416 ls3
Transmission: t65
Axle/Gears: Ford 9"moser 31 spline 350 gears
Ill take the dash..Pm me the price with shipping to 57732
Old Jul 25, 2023 | 08:28 AM
DethVenture's Avatar
Car: 1992 Camaro RS
Engine: L03 5.0L
Transmission: 700R4 Auto
Happen to have a TBI air cleaner and snorkel still?
Old Jul 25, 2023 | 09:04 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
If he doesn't have one, I have a near perfect one.
Old Aug 20, 2023 | 08:44 AM
Mr.ChevyStroker's Avatar
Car: RS Camaro
Engine: 97 L31 350:Eventually a stroker
Transmission: WC T-5
Axle/Gears: Zexel Torsen 3.73s
What year and engine set up is the dash harness for?
Old Aug 26, 2023 | 10:03 PM
RestoRoc89's Avatar
Car: 1987 Iroc-Z/1993 Z28/2011 Corvette
Engine: 350 CI TPI/355 CI LT1
Transmission: 700R4/D&D Performance T56
Axle/Gears: 3.27 9-bolt/3.73 10-Bolt
The heater core box — is it from a car with A/C?
cmc38camaro
Aug 5, 2018 11:46 AM
IR0CZG~0~D
Exterior Parts for Sale
Oct 18, 2011 11:37 PM
