Holley Terminator X Max - $1400.00
Old Jun 17, 2024 | 06:22 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
This is the Terminator X Max 530-931T system for the drive by wire system (58x reluctor wheel). This system does not come with the DBW pedal, throttle body, or transmission controller, and must be programmed with a laptop (Laptop CAN cable is included with the kit). I had this installed in my Camaro with a built 6.0L/T56 and it ran like a champ. There is a tune already loaded but will need to be updated based on your application. The only reason I pulled it out was to swap the system to a GM harness/PCM.
Old Jun 19, 2024 | 02:23 AM
Tpipickup2's Avatar
Re: Holley Terminator X Max - $1400.00
Why are you going back to a gm pcm after running this setup?
Old Jun 19, 2024 | 12:14 PM
1981LT1's Avatar
Engine: LT1; LT1
The Holley doesn’t support the VSS for my T56 so I had to buy several different modules and adapters to get my Speedo to work. In the end i also wanted an actual diagnostic port to interface with everything.
Old Jun 20, 2024 | 11:36 AM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
ive been running the factory ecm for 10 years now no issue. I honestly prefer it. But i know terminator for most is the way to go.
TransAm4Ever86
Dec 9, 2023 01:01 PM
DynoDave43
Aftermarket Vendor Review
May 29, 2023 12:02 AM
iroc-germany
European Region
Oct 1, 2020 05:39 AM
gad
Aug 21, 2011 09:57 PM
79malbiu
May 29, 2007 10:32 PM
