[Sold] TBI PERFORMANCE PACKAGE
Old Oct 27, 2024 | 02:45 PM
SNCTMPL's Avatar
Want a title? Post!
Car: 94 k1500
Engine: 383
Transmission: 4l60e
Axle/Gears: 14 bolt 4.56
I thought I would post this up here and see if anyone could use this. I also have it posted on GMT400. The package will contain the following.
  1. Edelbrock 3704 - bored to 2”, The intake is bored out to 2” and the four center bolts have been machined so it can go on the older heads as well. All the machined surfaces are clean and flat, and all threads are clean and not stripped.After machining we ran it through the jet-hot pressure washer for a while and it is super clean with a fresh coat of Seymour’s Alumi-blast.
  2. 50mm SBC throttle body, The 50mm throttle body is complete with matched 61lb/hr injectors that were recently cleaned, serviced and flowed at MRP Injectors. It is a small block unit, not the big block one. It has an aluminum pod spacer, adjustable regulator and pressure gauge. It has all new o rings and diaphragm for the regulator. It also has a brand new Delphi IAC and AC Delco TPS.
  3. 46mm SBC throttle body, The 46mm is an older Turbo City unit with oem TPS & IAC from my old 94. It is the base unit only, no injectors.
  4. CFM Tech phenolic spacer with gaskets - bored to 2”, The spacer and the gaskets were bored out on a milling machine while bolted to the intake, so the holes line up perfectly.I’m also throwing in a billet block off for the fuel regulator, so an external regulator could be utilized.
  5. MSD 8366 billet distributor, The MSD distributor was recently gone through and has a brand new DUI cap and rotor, also a Summit ignition control module. It has a Comp Cams composite gear and comes with an extra melonized gear.
  6. Dynamic EFI EBL Flash II, The EBL Flash speaks for itself. It has never been installed and is just the way BobR packed it. RIP. It is the newest version, he had just built it earlier this year.
I am asking $1350 shipped to the lower 48.
I have never shipped to Canada but would be willing to do so after checking on shipping and adjusting the price.
I can do Venmo or PayPal, fees will be added if using PayPal goods and services.
Everything is in nice shape and in perfect working condition. We are just switching to the Holley Terminator on our build.
I am not going to break the package up.
I have a ton of pictures, or you could look here, https://www.gmt400.com/threads/tbi-p...package.70241/
Let me know if you have any questions. Thanks for looking, Chris
Old Oct 27, 2024 | 10:22 PM
SNCTMPL's Avatar
Want a title? Post!
Car: 94 k1500
Engine: 383
Transmission: 4l60e
Re: TBI PERFORMANCE PACKAGE
I also have an Innovate wbo2 gauge that is brand new. It will plug into the EBL Flash and allow for wideband tuning.
The package price would be $1500 shipped with the gauge.
Old Oct 28, 2024 | 07:16 PM
SNCTMPL's Avatar
Want a title? Post!
Car: 94 k1500
Engine: 383
Transmission: 4l60e
Pending
Carlos89
Aug 27, 2021 08:08 PM
Fastbird
Jan 6, 2020 10:39 AM
articwhiteZ
Sep 23, 2018 05:22 PM
firstfirebird
Aug 25, 2007 06:09 PM
