[CO] L98 TPI Parts - Everything But The Block!
Car: 1989 Trans Am GTA
Engine: 383 L98
I spent last year rebuilding my engine (amongst other things) and decided to go the sniper efi route. I saved most every component from the original engine as I replaced various systems in the process. Below is a list of what I'm selling, and I also have a google drive folder link with pictures of all items. Note - I live in the Denver, Colorado area but can ship as needed and will work with you to set a fair additional cost for that.
"donor car" is a 1989 Trans Am GTA with the 5.7 L98 TPI (had been upgraded to 383 stroker 20k miles ago)
Feel free to text me at 7twozero - three3one - 0ninefive8. I am happy to give more details on specific parts as desired.
https://drive.google.com/drive/folde...7D?usp=sharing
- TPI Intake Parts - $150
- Plenum
- Base
- Runners
- Gaskets
- Hardware
- Fuel rail and hard lines
- Distributor decorative cover
- TPI OEM Cold air intake assy - $125
- air cleaner box
- rubber intake tubes
- MAF sensor
- MAF mounting bracket
L98 Heads - $100 for the pairRebuilt / valve job about 20k miles ago
- Distributor + Cap - $10
- Flexplate - $15
- Valve Covers - $30
- Air filter / charcoal canister mounting plate - $10
- Starter - $15
- 2x primary mount bolts
- stabilizer bracket
Water pump - $5- Dual fans - $30 for the pair
Exhaust manifolds - $30 for the pair- Auto Transmission cross member - $35
- 4 mounting bolts included
- Brake pedal and bracket - $10
Coolant tank - $5- Radiator + Condenser rubber isolators - $10
- A/C compressor - $20
- Worked when removed
- Charcoal canister with solenoid - $20
- A/C evaporator - $20
- Alternator support brace - $15
- Partial rotating assy - $100
- Crankshaft
- Cast
- 3.75" stroke
- Don't recall mfg
- No PN visible
- Pistons / connecting rods
- Speed-Pro Hypereutectic Pistons H890CP30
- .030 over
- Camshaft
- Original
- Crankshaft
- Oil pump and screen with lock - $10
- Original (brass/copper) heater core - $30
- No leaks at time of removal
Remfg ECM - $50- Harmonic balancer - $5
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Re: L98 TPI Parts - Everything But The Block!
Do you have the A/C box that mounts on the firewall where the evaporator mounts into? I need that whole box.
Car: 1994 firebird
Engine: 427ci lsx bowtie block
Transmission: tremec t56 micro edged gears
Axle/Gears: Strange dana 60 with racing spool
Still have some parts left? Was this a Serpentine belt or vbelt setup for the accessories?
