WTB: SBC 305, near Pittsburgh PA
Old May 10, 2006 | 07:30 AM
sjc115's Avatar
Car: 1984 Camaro
Engine: 350, 4bbl
Axle/Gears: GM, 3.23 posi
WTB: SBC 350 or 305, near Pittsburgh PA
I am looking for a relatively fresh 350 or 305 small block chevy. Must be within a 2-3 hour drive of Pittsburgh PA (erie, columbus, altoona, morgantown, etc.).
Long block or complete motor is preferred, but will consider anything that is fresh. Carb or TPI. If TPI, I need the wiring harness and computer also.
Pm or email me.
Thanks,
Steve
Old May 11, 2006 | 07:47 AM
sjc115's Avatar
Car: 1984 Camaro
Engine: 350, 4bbl
bump
Old May 14, 2006 | 04:51 AM
92fbodylover's Avatar
Car: 92 rs camaro ,92 covt trans am
Engine: 305 tpi , 305 tbi
Transmission: auto
305 motor
I have a ex 305 tpi motor. No longer have the tpi. But have from the heads down. ran when pull and has been setting in my since it was pull. I'm in virginia beach. But from pittsburgh, Pa Let me know how soon you need the motor. as I can run it up to pittsburgh for a small fee
Old May 14, 2006 | 03:24 PM
sjc115's Avatar
Car: 1984 Camaro
Engine: 350, 4bbl
PM me with details on the motor (casting numbers, how many miles on it, how much do you want for it, how much to bring it to pittsburgh, etc.).
Old May 14, 2006 | 03:36 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
how much are you looking to spend? I have a fresh 350 with about 6k on it. I pulled it out b/c I build a 383. I would like to see about 1700 OBO for it, and thats for oil pan to carb. im about 7 hours from you though. NY zip 12566.
It made 362 flywheel HP on the dyno. If your interested let me know, and ill let you know more about it.
Old May 14, 2006 | 05:48 PM
Transmission: auto
cast numbers block 14088551, heads 14014416. I looks at my notes from that 87 iroc. the preious owner had a gm rebuilt motor drop into the car at 87,900. and when I pull it it had about 99,010. on it. car was hit in the pass door / quarter panel . Dump truck ran a red light. . As I told you in the the post It has not accessories like water pump a/c pump etc. Also I had a guy came but and look at the motor and he told the pan off And I can not find it or the oil filter pick-up. I was asking 300 for the motor but I will take 200. and I split the cost to drive up to pittsburgh and that would be 120. so your total would be 320. let me know what you think
Old May 15, 2006 | 04:39 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
I live in Millsboro Delaware, fresh 350 , it was dipped, honed, freeze plugs, cam bearings ect.
Orr89RocZ
Feb 13, 2016 10:04 PM
masonta
Aug 31, 2015 10:14 PM
theurge
Aug 21, 2015 12:46 PM
TA8487
Aug 16, 2015 12:21 PM
Mister_Johnny99
Interior Parts Wanted
Aug 14, 2015 12:59 PM
