MAF relays and connectors
Car: 1991 Camaro RS
Engine: 87 350 TPI W/ Bells and Whistles
Transmission: Auto W/3000 stall
Axle/Gears: 3.42 POSI
I need the weatherpack connector plugs / relays for the MAF power, Maf burnoff and fuel pump 87-89. I figure the guys converting MAF to SD may have the bracket w/ connectors and relays lying around and might be willing to part with them for a fist full of dollars...Also, I could use a oil sender switch for a camaro 88-92.
...Any help is appreciated...
email: yeah711@verizon.net
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
Ive got the relays and the bracket..but Ill have to check on the conectors.. Im 99% sure Ive got them but Ill check tonight and post back... these were from an 87 trans am but should fit all the same..
BumpaD82
Feb 26, 2016 02:57 PM
MikkoV
Sep 9, 2015 04:25 PM
