WTB TPI 90-92 wire harness
Car: 89 conv iroc
Engine: tpi 350
Transmission: 5 speed
I have 85 tpi set up. I'm looking to up grade. l'd like a stock set up with ecm/prom & complete wire harness. 5.0 preferable. I could use map sensor ,knock sensor. Harness must be almost perfect. I have cash and or trade. Lots of goodies.
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
Car: 1992 Camaro Z28
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
So are you looking to go from MAF to Speed Density because if you just get a newer TPI setup you will see no performance gains, maybe 5hp with the Switch from MAF to Speed Density but thats it. I have a complete TPI setup from an 89' GTA wiring harness, injectors, and everything $400 shipped.
Car: 89 IrocZ
Engine: L98-ish
I know you want "perfect", but I have an SD harness that I removed from a running Monte Carlo conversion, also have the painless diagram to go with it. Honestly don't know if it's a Painless or a GM.
Since you're in Fresno, it would be too much (about 2 hours IIRC) for you to drive up and look it over.
100 bucks shipped or pickup for a somewhat local guy like yourself
TA8487
Aug 16, 2015 12:21 PM
Sanjay
Aug 12, 2015 03:41 PM
