wanted: 9bolt rearend w/ 3:23 or3:42 gearset(posi -drumbreaks)
Subscribe
Aug 16, 2006 | 08:50 PM
hey i am looking for a 9 bolt posi rear end with drum breaks and a 3:42 or 3:23 gearset in it , to replace the 10 bolt in my '91 z28 I bent the axels and trying to find them is more difficult than finding a whole new rearend and the 9 bolts are much stonger. thanks.
Reply 0
Aug 16, 2006 | 09:26 PM
9 bolts are 3.27 or 3.45 or 2.77 gears
good luck finding a 3.45 geared one though.
Reply 0
Aug 22, 2006 | 08:00 PM
If you're still looking, I've got two very nice 3.45 9-bolt posi setups. Both C clip elim. Both disc brakes. One is complete to rotors. Asking $750. The other is minus brakes. Asking $500. email indianavette@aol.com for pix, info.
Reply 0
Aug 22, 2006 | 08:55 PM
I HAVE A COMPLETE PBR 9-BOLT REAR WITH 3:27S FOR $300 IN Connecticut
Reply 0
Aug 26, 2006 | 01:45 PM
rear end
ive got a 9 bolt that i broke the gears in they were 3.73, there are no brakes on it now but it was a disk rearend 60.00 im in oklahoma
Reply 0
Aug 26, 2006 | 10:27 PM
Quote: If you're still looking, I've got two very nice 3.45 9-bolt posi setups. Both C clip elim. Both disc brakes. One is complete to rotors. Asking $750. The other is minus brakes. Asking $500. email indianavette@aol.com for pix, info.
How did you eliminate the C-clips in a 9 bolt?
Reply 0
Aug 27, 2006 | 12:08 AM
Quote: How did you eliminate the C-clips in a 9 bolt?
was wondering that myself considering THEY DONT HAVE THEM.
also might want to give an area where you are...
I have a 3:27 LSD 12" disk rear in southern Il. 275 picked up.
Reply 0
Aug 31, 2006 | 07:54 AM
Interested in replacement axles ??
I've got a pair of good Axles from a 91,....... I pulled them from the rear end about 2 months ago.
Make me an offer and send me your ZIP CODE if your intrested in buying them. I'll use your ZIP code to get shipping quotes for you.
P.S. 9-Bolt axles are bolted to the axle flange on each end of the housing - no need for a C-Clip.
Reply 0
Aug 31, 2006 | 08:33 AM
AFAIK all 9 bolt rears were disc brake
Reply 0
Oct 27, 2006 | 12:07 PM
i have a 9 bolt with 3:91 gears in it and i have an extra set of 4:11 that i will put with it if you want.
Reply 0
Subscribe
