need a cam/springs
Old Sep 5, 2006 | 08:12 PM
pr0zac's Avatar
Car: 1991 z28
Engine: forged 385 with afr's
Transmission: built 700r4
Axle/Gears: 9" and 4.56
need a cam/springs
wondering if anyone has a larger than stock hydaulic roller cam for either an lt1 or a 87 up block. also if you have matching springs for it too.. doesn't need to be brand new. thanks.
Old Sep 5, 2006 | 08:53 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I have some very good springs that are new in the box isky #235-D I got them with the cam I have in my 89 formula 350. since my heads used a larger diameter spring I never used these. these will fit stock size spring pockets and will work great with cams around the lt4 hotcam specs or similar. I really have no use for them so shoot an offer and I am sure we can work out a smokin deal for you!
I have a unused l98 cam as well if you are just looking for something to run with some 1.6 rr.
Old Sep 7, 2006 | 08:50 PM
badazta87's Avatar
Car: 87 GTA
Engine: Under Construction
Axle/Gears: 3.70:1
I have a zz9 cam from TPIS has about 3000 miles on it. make an offer
Old Sep 7, 2006 | 10:16 PM
FORMULA355TPI's Avatar
Car: 88 FORMULA / 88 IROC
Engine: 355 / 355
Transmission: T5 / TH400
Axle/Gears: 10 Bolt-3.73 / 9"-3.90
I have a blue racer roller hydraulic for factory roller block.. It came with a motor I bought. But I decided to pull it to go with a solid roller unit.. I have the cam, lifters, spider, links, and thrust plate.. I do not have the spec card for the cam but the grind number is 960840.. The cam was never ran but was oiled and installed. $150 for everything..
Josh
215-783-4645
Old Sep 8, 2006 | 04:29 PM
pr0zac's Avatar
Car: 1991 z28
what are you looking to get? do you have springs?
Old Sep 8, 2006 | 04:30 PM
pr0zac's Avatar
Car: 1991 z28
where could i find specs on this cam??
Old Sep 8, 2006 | 04:50 PM
pr0zac's Avatar
Car: 1991 z28
Old Sep 9, 2006 | 09:00 AM
Engine: 355 / 355
Mine? I really dont know, Crane bought Blue Racer so theyre records are pretty inacurate and sometime non-existant.. If you are interested I will have it checked out...
robbe_iroc
Dec 1, 2014 03:55 PM
25th327RS
Dec 4, 2013 01:01 AM
BlueMagicSS
Northern California
Nov 30, 2012 11:02 AM
