A/C Delete parts
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
A/C Delete parts
I need everything to delete A/C from the Non-AC heater box to the HVAC Controls and everything inbetween. I do not need the AC delete pully.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I've got a full non a/c camaro dash, heater box and vent sliders. Basically, it's a complete dash & heater assembly out of a non-a/c car.
I'm asking $200.
I'm asking $200.
Engine: L03, LS1
Didnt know the dash itself was different? Can i get away with just the HVAC Controls and the heater box? I presume the heater box is the part you see under the hood?
A non a/c dash doesn't have the cutouts for the vents in it, and instead it has slider controls under the driver's side that opens vents under the dash.
The whole heater box is different, inside and under the hood. However, you can retain the a/c heater box under the dash and just replace the piece under the hood if that's all you want to do. I don't think the non a/c HVAC controls will work properly with an a/c box though, so you'll have to keep your current HVAC controls if you don't change the box.
What are you trying to do? Do you just want to get rid of the a/c box under the hood, or do you want your car to look like it never came with a/c? If you want the latter, you need everything. If you just want the former, you can get the under-hood part for $50-80 on ebay.
LT1Formula
20
Nov 14, 2015 12:02 AM
