Looking for LT1
Old Nov 8, 2006 | 08:50 PM
TAB778688's Avatar
Looking for LT1
Hi, I been recently restoring my 91 Camaro RS. I tossed the idea of building the stock 305, then possilby a 350. Now i have decided to just go all the way and go with an LT1. I'm on a tight budget and i would like spend under $1000. I will consider short blocks if anyone has one they would like to sell. I am also looking for complete harness.
Also looking for resonably priced T56.
Old Nov 8, 2006 | 11:24 PM
tpi-hearse's Avatar
Car: 1989 Iroc, 1987and 1989 formula 350
Engine: 305tpi,350tpi,ls1
Transmission: 700r4,t-56
Axle/Gears: 3:08,3:27,3:23
location?
Old Nov 9, 2006 | 02:32 AM
TAB778688's Avatar
Ct area if possible. I have no problem paying for it to be shipped depending on where it is.
Old Nov 9, 2006 | 08:59 AM
tpi-hearse's Avatar
Well I am in Ct and have a complete 1993 Lt1 out of a formula...$900
Old Nov 13, 2006 | 08:16 PM
camaroboricua's Avatar
Car: 1990 Camaro RS
Engine: 355 c.u.
would you be interested in a block with only internals and oil pan? the motor dropped a valve and one of the pistons shattered so it caused slight damage to the cylinder wall. its a good block for a stroker kit if you plan on rebuilding...
Old Nov 16, 2006 | 11:29 AM
Jeffluke's Avatar
Car: 90 L98 IROC/87 LB9 NM5 1AZ / 96 TBI 350 700R4 XCAB S-10..LT1 SOON
Engine: L98/LB9/LT1
Transmission: 700R4/WC-T5
Axle/Gears: 3:73
I have a salvage yard friend who just obtained a full size 94 cad hit in the rear, 94 LT1/4l60, very good cond, and he will ship it all w/harness if you cant find one on your end, I am pretty sure he still has it, let me know Jeff
Old Nov 18, 2006 | 12:10 PM
LT1Formula's Avatar
I don't know if the money is doable, but I have a complete engine, 700R4 trans , and wiring harness with computer from my 91GTA for sale. The engine has 86 K on the short block and 1K miles on new Trick Flow 23 heads. The TPI is an ASM ported base with large tube runners, and ASM ported plenum with ASM polished throttle body. the entire TPI setup was polished by ASM. The cam is also ASM with similar specs to Lingenfelter TPI cam. It runs great and has an ASM chip matched to these components. It comes with SLP shorty headers. This would look sharp in your Camaro. $1500 plus shipping for everything. Bill
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
