wanted: a electronic speedo sensor for a 700 r4
Car: 89 Camaro RS Convertible
Engine: 355 chevy power
Transmission: 5 speed manual
Axle/Gears: standard
just as the sub says apparently the trans was an 86 but it was in my 91 camaro. I need a electronic speedo. it has to be the bigger plug as i have one for a 5 speed but that didnt cover up the hole. know what im talkin bout.
Axle/Gears: '01 3.42 10 bolt
you need to post the tooth count of the driven gear. there are two different speed sensors. the one for the 35-39 tooth and the one for the 40-45 tooth.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
What is your rear end gear ratio?
Can you see what color the gear INSIDE the tranny is ??
And what do you want for the T5 sending unit ?
damn it had a standard 2.73 rear end ratio. i dont know about the color though if you have a non electronic speedo unit for the t5 ill trade
FormulasOnly
Sep 10, 2015 09:07 PM
