1987 Z28 Camaro CARB wanted
Old Feb 3, 2007 | 12:33 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
not sure what they are going for, let me know what you've got and how much. Thanks
Old Feb 4, 2007 | 09:22 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Not sure if its what you're looking for since I don't know what kind of combo you are matching it with. I've got a Promax 750DP carb that I would like to sell for $275. Promax is carb shop in gasoline alley...its basically the same as a proform race carb. It has 4 corner idle circuit, screw in air bleeds, billet aluminum metering blocks ect. Its as good as new and was modified for my current combo(larger squirters, changed accelerator pump cams, drilled throttle blades) but could easiely be put back to how it was when bought new if needed. I bought it a couple of years ago for about $450 new and have all the orginal paperwork. send me a pm or email at camarof41_383@yahoo.com if you are interested or want a pic of it.
Old Feb 4, 2007 | 10:23 AM
Engine: 5.7
I'll have to check with my brother to see what he wants to do. We have had his carb rebuilt...and the car still runs really bad. It won't start unless we pour a little bit of gas down the carb. It's getting to the point where we have to start replacing things to see if it helps. Figured we'd try a carb. Thanks for the post and I'll let you know.
Old Feb 28, 2007 | 08:19 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
I got a nice shiney Carter comp AFB carb. It's near new with an electric choke. Here is the link to the stuff I have for sale.
Let me know.
https://www.thirdgen.org/forums/engi...lt-carter.html
Pics are near the bottom of the thread.
Thanx
Old Mar 5, 2007 | 11:58 PM
85ta5sp's Avatar
Car: 85 Trans Am,90 Camaro RS
Transmission: t5
have a 750 speed demon vac. 375$ ran 5 dyno runs great carb
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
beachrodder
Aug 25, 2015 08:05 AM
jahblah
Aug 12, 2015 05:54 PM
