WANTED ASAP -- MAF plug, the one that plugs into the unit itself...
Old Mar 4, 2007 | 06:52 PM
BigBoi4Lyph's Avatar
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 9 bolt Borg Warner Disk Brake Posi
So im buying a car and i need this plug with about 6-8 inches of the wires still on it all the junkyars out here dont have any and my car is barly starting right now its an 89 iroc 350 TPI so if anyone can help me out that would be great! Thanks
MAF plug i beleave its 5 wires comming off the plug. thanks
Old Mar 4, 2007 | 07:05 PM
LB3's Avatar
LB3
Car: 1987 IROC
Engine: Built 350 TPI
If you could get us a pic it would help a lot..We have a few in stock just need to see to make sure it's the same or we can find the right one..
Larry
Old Mar 4, 2007 | 07:10 PM
Car: 89 Iroc
Engine: 5.7 TPI
Ok will do im gettin the car in about an hours so ill get that pic and put it up tonight thanks alot! Hopefully the car will run perfectly with that Then i can really put the posi disk rear end to its limits
Old Mar 4, 2007 | 08:34 PM
Car: 89 Iroc
Engine: 5.7 TPI
And here they are this is a pick of the fried plug but i wire colors are Green Blue Red, black, black w/ white stripe. and its a 5 port female conector and heres the pics that would help even more keep in mind this one is all kinda of messed up but this should give ya an idea! Thanks
Old Mar 4, 2007 | 08:51 PM
LB3's Avatar
LB3
Car: 1987 IROC
Okay, We will start looking ASAP.. Larry
Old Mar 4, 2007 | 09:04 PM
Car: 89 Iroc
Engine: 5.7 TPI
That would be great thanks!
Old Mar 5, 2007 | 10:43 AM
Thomas's Avatar
Car: 87' Pont GTA
Engine: 5.7L
Try www.tpiparts.net! They are a great company and very helpfull. They are also a sponsor of this this great website. Good Luck!!!
Thomas
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
jharrison5
Aug 19, 2015 05:53 PM
