Interested in L98/G92 Exhaust Manifolds & Y-pipe
Car: 1992 Z28 (Heritage Edition)
Axle/Gears: 2.73 Posi
I am interested in a set of exhaust manifolds and & y-pipe from either an L98 car or a G92 305 car.
I really want my car to have a super stock experience, as i am a big fan of stock and i figure that if i want to add alittle bit of performance i could upgrade to the bigger exhaust manifolds/ypipe and it would still look as if it came right from the factory. Also, i would want all AIR tubes to be intact.
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Re: Interested in L98/G92 Exhaust Manifolds & Y-pipe
I'm pretty sure I have a spare set of manifolds with AIR tubes from a 350 TPI out in my garage. Any way I can ID them as being from an L98?
If you are interested, send me a PM...I have no idea what to ask for them.
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
If i remember correctly stock 350 TPI exhaust manifolds have a larger exit ID than the 305 manifolds. I'm pretty sure I have what you are looking for, I will get back with you later on.
Sounds good. Ideally i'd need the y-pipe too, since the larger manifolds would be of no use to me without the manifolds to hook to them.
Car: DEPENDS ON WHAT DAY IT IS
Engine: 428 STROKED TO 462
Transmission: 6 SPEED
I GOT THEM OFF A 91 Z28 TPI 305, WITH SMOG RAILS $150 FOR IT ALL PLUS SHIPPING
559-213-2752
ERIC
559-213-2752
ERIC
Car: 1988 GTA
Engine: 383 Stroker L98 TPI
Transmission: 700 R4 w/ B&M Shift Kit
Axle/Gears: Stock BW LS 9 Bolt with 3.27 gears
I have what you need and you may be able to pick up if you want to avoid shipping cost. My zip is 19348
Mike
Mike
transaero
Aug 31, 2015 01:14 AM
