WTB: Wiring Harness to match my ecm!!!
hi, i bought a 85 tpi setup, that came with a partially cut harness... and i dont want to mess with it, the ecm i need the harness to match is 01227165. i am worried cause i think this ecm is for 86-88... not sure.. just need all the wiring to get it running. its a swap to a car that didnt have a tpi.. so i think i need the fuse block and relays and all i think... needs to have the plug for the small cap dist, will pay extra if you have the dist and coil, and will pay extra for a matching maf also.
Car: 01 mustang GT
Engine: 4.6
Transmission: tr3650
Axle/Gears: 3.73 Posi
What year is your car. I have a complete 85 wiring harness and it will work with your computer it is uncut out of an 85 camaro uses the HEI dist. If your car is an 85 It will plug into your under dash connector and run like a top. other wise you will have to splice into the right wires on the under dash end. 325-280-9989 if you have any questions
P.S. I also have the maf and tubing for the camaro. I am needing the speed density tube for a camaro.
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Re: WTB: Wiring Harness to match my ecm!!!
I have an uncut 1985 TPI harness with CPU and two chips...one from TPI.com and the other a Superchip. $100 plus shipping. I'll throw in the correct throttle cable if you need it.
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
TA8487
Aug 16, 2015 12:21 PM
