Need a Few TPI Plenum, Runner and Intake bolts
Old Mar 20, 2007 | 07:26 PM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
Guys/Gals looking for any misc tpi intake , plenum and runner torx bolts you may have lying around. I don't have any (that I can find)....If you have even one bolt it will help, could also use a waterneck and the tiny torx distributor cover bolts as well, along with the cover. See what you can scrounge up for me and let me know. I know these aren't big ticket items , but it will help out a fellow member at the least. thanks in advance.
Old Mar 20, 2007 | 09:39 PM
madhatter's Avatar
Re: Need a Few TPI Plenum, Runner and Intake bolts
i have a complete tpi setup, intake, runners, throttle body, upper plenum, fuel rails, fuel pressure regulator,fuel injectors, complete distributor, water neck, and bolts
would like to get 200, so pm me if your interested
Old Mar 21, 2007 | 04:05 PM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
I have everything but the bolts(thats what I'm looking for). Trying to put a set together for a friend. Thanks for the bump .
Old Mar 21, 2007 | 09:24 PM
madhatter's Avatar
sorry read it wrong, you can always go to the hard ware store and get bolts to fit, it helps if you dont have to worry about stripping out the torx pattern
Old Mar 22, 2007 | 04:36 PM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
thanks fore the bump. I was trying to keep things original...Allen head bolts do work well though. I will keep looking.
Old Apr 8, 2007 | 01:21 AM
jcsereiko's Avatar
Car: 1989 Iroc Z28
Engine: TPI 5.0
Axle/Gears: Stock
how many do you need and what size, basically you have the short ones ant the long ones for the runners. I have a complete set, two of them are useable but not showcar usable. pm me with a offer. my zip is 60423, chicago ,il
evilstuie
Jan 9, 2020 08:29 PM
MantyZ28
16
Dec 21, 2015 11:02 AM
masonta
Aug 31, 2015 10:14 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Sanjay
Aug 12, 2015 03:41 PM
