stealthram intake ASAP
Car: 91 camaro z28
Engine: 383 with all holley performance
Transmission: 700r4 built for race
Axle/Gears: 3.73 limited slip
Re: stealthram intake ASAP
how much are u want to expend,i have 1 with 0 miles i put it on my engine but never used because still in project,it is polished with 30 lbs injectors,adjustable regulator fuel rails,and thermostat housing, and if you need i have the stock 52mm from my tpi.
Car: 1989 Trans Am GTA
Transmission: M28 T56
Why not buy directly from Summit then? Its not that much for just the upper/lower manifold and fuel rail kit.
I did the swap and total investment was $650 for EVERYTHING down to the last fitting. This was before I sold my TPI intake which dropped the total cost to about $300.
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
