I need Motor mounts....
Old Jul 5, 2007 | 05:35 PM
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
Looking for SBC motor mounts for 86 camaro. I have the frame pads. just needs the mounts
Old Jul 5, 2007 | 09:34 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: I need Motor mounts....
Are you looking for the "clamshell" that bolts to each side of the engine ??
$25 a pair + shipping ( for V8 )
Post your ZIP code if your interested so I can get you a shipping quote !
Old Jul 5, 2007 | 10:59 PM
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
Yeah. There for each side of the block and they mount over the frame pads. I have never actully seen them but this is what im told is right for my application. SBC into 86 Camaro.
I'll pay but it would help if you could shoot me a picture. My zip is 19064.
Thank you very much!
Old Jul 22, 2008 | 09:11 PM
91camaroRSx383's Avatar
Car: 91 Camaro RS
Engine: 383 Stroker
Transmission: T5 Wolrd Class
Axle/Gears: Open 3.27 gears
i got a pair ill sell you for 15+ shipping PM me if you want em or some pics
Old Jul 27, 2008 | 08:30 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
howdy there
what you refer to as being the pads are the actual engine mounts
and what you are looking for are simply the brackets that bolt to the engine block
and they are the same bbc and sbc 69-up most cars and 73-up trucks
and vans
i have noticed over the years that some of the truck ones are a little deeper than car ones
and some cars use a triangle shaped spacer plate between the mount and the engine block when using the shallower depth car brackets
it can really mess you up and prevent bolt hole alignment
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
madsv1000
Aug 20, 2015 06:45 AM
slade5612
Aug 11, 2015 07:19 PM
