LT1 short block
Old Sep 16, 2007 | 09:10 AM
ncnightstalker's Avatar
LT1 short block
want a LT1 short block would take a long block or complete engine if the price was right......closer to NC the better
Old Sep 16, 2007 | 09:04 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: LT1 short block
$200 + shipping.
Old Sep 17, 2007 | 05:52 AM
Re: LT1 short block
what kind of mileage has that got on it?
Old Sep 22, 2007 | 07:08 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Re: LT1 short block
It was around 120k. Still has the crosshatch on the cylinder walls.
Old Sep 26, 2007 | 06:02 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Re: LT1 short block
I have a complet LT1 (only short block together) I also have the wiring uncut the comp,It has a cc503 came in it I have all paper work where I had the block resurfaced,heads cracked checked .New stock pistons. I also have a nib timming chain. Heads dose not have the valves or springs in them I was going to get them ported. But have all valves,springs... and new bottom half gasket kit. Make a offer.
Old Oct 18, 2007 | 02:31 AM
CamaroZ2869C's Avatar
Car: 91 camaro rs
Engine: 305 up grading
Re: LT1 short block
lt1 383 12:1 forged bottom end, splayed 4bolt, 1" hard block, LE3 heads, cca468 (242/248 .584/.579 @050), 1.6 roller rockers, comp lifters, pacesetter LT's, 3" ory, 58 mm t/b, walbro 255, fuel regulator, msd wires, accel shorty plugs, crane fireball box, miezer electric water pump, march under drive pulley, gm performance timing set, 44lb injectors, all accessories, new o2's and extensions, based off similar build( has not been dynoed tuned yet 450-500 rwhp through an auto on pump gas. motor has 600-700 miles over $8k in it take $5500 turn key
New2Chevy
Sep 28, 2015 12:35 AM
Kenwood
Sep 11, 2015 12:50 PM
64goatman
Sep 9, 2015 01:09 PM
L0tuS
Sep 4, 2015 11:16 PM
