1986 TPI Parts/Info needed
Old Oct 7, 2007 | 11:10 PM
dunesie's Avatar
I'm converting an '86 SC from carb to TPI. I need the oil pressure riser from the rear of the block that has the oil pressure sensor and fuel pump oil pressure switch mounted to it. I also need a TV cable and cruise control cable for TPI. Anybody with an '86 TPI car could really help me out with some photos of the front of the TPI plenum/manifold area showing hose routing and throttle body details. Also the area where the MAF relays mount to the right of the brake booster. A Bosch MAF sensor would be great too.
Thanks for the support! If you have any of the parts, let me know what you want for them. Hopefully we can work out a deal.
Duane
Old Oct 8, 2007 | 10:18 AM
doppler's Avatar
Re: 1986 TPI Parts/Info needed
Will a 1987 MAF work? I have one currently on a running TPI, I'm getting ready to convert it a carb.
$100 shipped.
Old Oct 8, 2007 | 11:57 AM
dunesie's Avatar
What motor does your '87 have? 5.0 or 5.7 liter? According the references, they used different MAF sensors.
Thanks,
Old Oct 8, 2007 | 12:15 PM
merlin6744's Avatar
Car: 1985 Iroc
Transmission: 700R
Axle/Gears: 3:27 posi
I have a 350 TPI from an 87 Iroc in my car. Email me @ merlin6744@gmail.com if you still are needing some pics.
Old Oct 8, 2007 | 12:45 PM
doppler's Avatar
Sorry about that, it's a 350 TPI.
Steven 86IROC-Z
May 24, 2026 04:52 AM
IROCZ1989
Jan 24, 2016 03:55 PM
Sanjay
Aug 12, 2015 03:41 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
