Need new or used RETROFIT ROLLER CAMSHAFT, around 0.500" lift
Old Oct 14, 2007 | 12:56 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Hi guys, I had purchased a custom grind 0.495"/0.530" roller camshaft on this board a while ago, but it is an 87+ L98 style cam. I need a similar lift RETROFIT ROLLER CAM because I am going to be using an older block. Some people cobble the 87+ roller into an older block, but I am not comfortable doing this, so I need a real retrofit roller camshaft. There is no good way to use the thrust plate with an older block -- people take the thrust plate form an L98 and cut the ears off and use it as a "shim", but I tried mocking this up and there is just too much slop doing it this way to be a legit install.
Please let me know ASAP, as I will be buying a new off the shelf retrofit roller cam from Summit later this week if I can't come up with something lower priced. Thanks!
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Agent507943
Camaros Wanted
Oct 2, 2015 07:17 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
