3" cat needed.....perfer a tpi 3in
Old Oct 25, 2007 | 03:37 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
HI i am hooking up my new exhaust and need a 3inch cat to pass visual inspection for a salvage title. Basically they said the exhaust needs to be in functioning order......thats all. So, i need a cat i cat put on my car.....i prefer non gutted.....but a cheap gutted one might work.
THANKS, Shelby
Old Oct 25, 2007 | 08:12 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Re: 3" cat needed.....perfer a tpi 3in
I have a 3" one off my car. Not sure on its efficiency and you'd need to weld it on (it was cut off) but it should be fine for a visual. Let me know if you're interested.
Old Oct 26, 2007 | 11:01 AM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
How bad is it cut up? I need something i can slip on header y- pipe end and bolt on the other end.
Bump....needa good cat
Old Oct 26, 2007 | 08:19 PM
Car: 1989 IROC-Z
Engine: 383 stroker
It's not "cut up", just cut off. The ends are clean cuts. You could have an exhaust shop weld a 3-bolt flange to the y-pipe and the catback. Then put a couple 3-bolt flanges on the cat and bolt it in. Also have them cut a piece of pipe the same length with a flange on each side so you can swap the cat out. I'll get you a pic if you want.
Old Oct 27, 2007 | 01:09 AM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
Picture would be cool, also how much are you lookin for? See i have a hedman y-pipe that came with an adapter to go 3in cat....it slips on like the tpi cars. The other end has a two bolt flange that bolts to my 3in catback. See what im talkin about? I want to know how it was "cut up"
Thanks, shelby
Old Oct 27, 2007 | 03:40 PM
Car: 1989 IROC-Z
Engine: 383 stroker
What's your email? I'll send you some pics.
You can get a new cat for pretty cheap, you might be better just doing that.
Old Oct 27, 2007 | 04:03 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i have a catco that was used for 1000 miles on my truck. 3" high flow kind, was $100 new, sell for $50 shipped.
PM me if interested as I don't check the for sale boards ever.
Old Oct 30, 2007 | 05:07 PM
Beast407's Avatar
3" PFP Cat With 3-Bolt Header Flanges: $60.00 shipped
Attached Thumbnails 3" cat needed.....perfer a tpi 3in-cat-1.jpg   3" cat needed.....perfer a tpi 3in-cat-2.jpg
Old Nov 2, 2007 | 01:46 PM
IROCZ_L98's Avatar
Car: 1987 IROCZ
Engine: 355, Vortec Heads, Carbed
Transmission: TH350, 2800 stall
Axle/Gears: 3.27 9 Bolt
I have one still on the y-pipe with the stock flanges on it, pm me if you are interested.
LT1Formula
20
Nov 14, 2015 12:02 AM
Out-Cast
Aug 22, 2015 07:49 PM
chazman
Aug 22, 2015 02:01 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
