ported/good shape 305 TPI heads
Old Nov 20, 2007 | 11:29 PM
89IrocPballa's Avatar
Car: 1989 Chevrolet Camaro Iroc Z
Engine: LO3
Transmission: 5 speed
Axle/Gears: stock
i would like some used 305 TPI heads and it would be great if they were ported but stock will do.
Old Nov 22, 2007 | 04:36 PM
jerflash's Avatar
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
Re: ported/good shape 305 TPI heads
look here dude and check out my heads i have for sale
fully rebuilt 305 tpi heads with 3 angle valve job
https://www.thirdgen.org/forums/engi...081-305-a.html
Old Nov 23, 2007 | 09:02 PM
KrazedZ's Avatar
Selling a set of fully ported cast iron heads not just a gasket match here, full runner and bowl work, 64cc chambers, aftermarket valves with under cut stems for more flow, 1.94" intake and 1.50" exhaust. Heads are cleaned and assembled.
Heads flow just about 240cfm on the intake side at 0.550" lift.
These heads were off of a friends 79 camaro, he upgraded and i was going to use them on a project but have gone a different direction.
His camaro was running a consistant 11.80's at 116mph on motor, stock bottomend with flat top 4 valve relief hyperutectic pistons, single plane intake, 750 carb, compcams flat tappet single pattern 248 dur @ 0.050" cam (off the self cam), 1 5/8" long tube headers, 350 trans with a jegs converter, 3.73 gears and southside lift bars in a stock weight car, just listing his setup to see what these heads can do with a very average setup.
Casting numbers on the heads are 186 & 462, one head has accessory holes and the other doesn't, heads are the same in everyway from ports to chambers, setup this way so that you have two sets of usable heads rather then one set.
$400 for local pick up or add shipping.
Located in NJ 08721
Tony
email me any questions at KrazedZ@yahoo.com
Old Nov 30, 2007 | 08:40 PM
jerflash's Avatar
hey man so do you want my heads you have not posted anything
BlueIroc-Z
Jun 9, 2019 03:22 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
