I need a set of 16 hardened pushrods. I have checked with an adjustable and both a 7.30" and a 7.35" would work for this application. The standard 5/16" diameter is preferred.
I can buy a set new ranging from $55 - $119 so what I am looking for is a set of low wear used rods a good used price.
Thanks.
Thanks.
are these stock length pushrods for a solid cam or hydraulic flat tappet
or are u looking for roller ones?
I have a nice set of chro moly pushrods that are hardened in stock length, non roller cam applications
Originally Posted by xpndbl3
are these stock length pushrods for a solid cam or hydraulic flat tappet or are u looking for roller ones?
Stock length is 7.20" but because the heads are RHS Comp Cams after market heads the stock ones didn't work. It's a Vortec roller motor under the heads so it's a roller cam application. I have a set of moly rods, 7.50" length, but they are a tad too long. I fiddled with an adjustable and it looks like either 7.30" - 7.35" will work just fine.
I have a set of 7.350" Trickflows, 1-piece hardened. $65 shipped.
Quote:
Originally Posted by PLANT PROTECTION
I have a set of 7.350" Trickflows, 1-piece hardened. $65 shipped. Crap I wish you had found this thread a week ago. Just sent off $85 for a set. Still a good deal, but cheaper is always better. If for some reason there is a problem and they get lost on the way here I will let you know. Thanks so much for replying.
