Rear end bolts wanted
Old Feb 26, 2008 | 02:21 AM
phil67's Avatar
Car: 90GTA
Hello,
I'm looking for 8 bolts.
On a rear end with discs, the brakes calipers are fixed on a plate with 2 screws and the plate is fixed to the read end with 4 bolts. I look for the last 4 ones. (both sides, so 8 bolts).
My car is a 90 GTA with a std 3.23 rear end. Bolts have 9/16" heads with a small thread and 9/16" nuts.
Any proposal welcomed because my car is halted due to damaged bolts which are too dangerous.
Philippe
trans_sport95@yahoo.fr
France
Old Feb 27, 2008 | 07:03 PM
billymac49's Avatar
Car: 88 IROC
Engine: 5.0 tpi
Transmission: 700 r4
Re: Rear end bolts wanted
can you try to find grade 8 bolts & nuts
Old Mar 1, 2008 | 02:04 PM
phil67's Avatar
Car: 90GTA
Unfortunately, i believe it would be the solution, but that's very hard to find in retail in France.
Old Mar 21, 2008 | 05:45 AM
zepp777's Avatar
Car: 1988 camaro Rs (z-28 clone)
Engine: 305 tbi (building 383 stroker(
Axle/Gears: 3.73 and a ratchet locker
do u stil need the bolts for the rearend? if u do let me know and i can check the junkyard for u they put those type of rearends in alot of cars and it would be easy enough to go to the junkyard and get a bolt set to help another camaro lover out
Old Mar 31, 2008 | 05:08 AM
phil67's Avatar
Car: 90GTA
Hi,
Thanks for the kind proposal, but a friend of mine has just found them so, the firebird will run again in a few hours.
Phil
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
