waterneck/fuel lines wanted
Old Mar 25, 2008 | 11:22 PM
12secondSY's Avatar
Car: 99 S10, 87 S blazer, 87 S blazer
Engine: 4.3L, TPI 350, Carb'd 350
Transmission: 4l60e, 700R4, TH350
Axle/Gears: 3.42, 3.42, 4.10
I need the hard lines off the fuel rail for a TPI car. If not some barb fittings I can put in ther and run some rubber lines to but I havent been able to find them in those sizes and with the o-rings. All Ive found is the 6an adapters but dont want to spend money on the all the fittings that would take.
Might also take the rubber lines that connect to those, depending on price.
Also need a watereck from a TPI car.
Also if someone can also throw these things in cheap:
knock sensor(90-92 350 car)
Oil pressure switch, one from a car with the light, not the gauge if possible
This is for a VERY budget TPI swap in my 87 blazer. Im between jobs for a couple weeks but need to finish it up before my other truck sells.
Old Mar 26, 2008 | 07:37 AM
tpi-hearse's Avatar
Car: 1989 Iroc, 1987and 1989 formula 350
Engine: 305tpi,350tpi,ls1
Transmission: 700r4,t-56
Axle/Gears: 3:08,3:27,3:23
Re: waterneck/fuel lines wanted
$45 shipped for the waterneck...steel lines and rubber lines
Old Mar 26, 2008 | 01:34 PM
12secondSY's Avatar
Sending a PM
TheJoeY88
Dec 31, 2016 07:30 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
Jake_92RS
Aug 17, 2015 09:42 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
