WANTED!! LS1 PARTS FOR TTLQ4 BUILD
Transmission: 2000 t56
Axle/Gears: 8.8 hybrid/moser/tru trac/4.11s
this is pretty much all i need to finish the car!
steel braided brake line kit
eibach sportlines for thirdgens
rear mounted battery kit
wideband
rollcage padding
5 point racing harness'
dynomating or simular sound deadener
4" 90 degree silicone elbows
4" k&n cone filters
patriot gold dual springs
autometer's sportcomp ultralite gauges (speedo, tach, fuel press, fuel level,
boost/vacc, oil press, temp)
98+ slotted or cross drilled rotors
adjustable brake proportioning valve
tranny mount adjustable torque arm
2'' wheel spacers
60 lb high independance injectors
38 or 44mm waste gates
aeromotive a1000 fuel pump controller
a1000 100micron and 10 micron filter
located in richmond hill, ontario, canada. postal code l4s 1v6
wideband
rollcage padding
4" k&n cone filters
2'' wheel spacers
