MAF needed
Old May 31, 2008 | 05:57 PM
Samdweezel05's Avatar
MAF needed
If you have one or two of the factory MAF's kicking around I would be interested in them. Must be in working order and work on my 1989 GTA 350 TPI. Thank's
Phil
Old May 31, 2008 | 10:08 PM
Dokken10's Avatar
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
Re: MAF needed
I have one from a 89 GTA 350 TPI.
Old Jun 1, 2008 | 07:31 AM
Re: MAF needed
PM sent.
Phil
Old Jun 2, 2008 | 10:03 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Re: MAF needed
if you are local to WI you can have the one I have. I can't test it so if you picked it up it's yours. it was descreened and has been sitting for so long who knows if it's still good.(worked when I stopped using MAF) the wire looks like it's still attached fine but like I said it's free
Old Jun 12, 2008 | 09:34 AM
StreetDemon-Z28's Avatar
Car: 91 Camaro ILE Z-28 01 dodge ram
Engine: LINE UP AND FIND OUT , UR CAR HERE
Transmission: nOT ENOUFE
Axle/Gears: NoT enoufe
Re: MAF needed
I have 3 maf sensors that will all work with ur car let me know NJSC007@AOL.COM THANKS
IROCZ1989
Jan 24, 2016 03:55 PM
NBrehm
Aug 25, 2015 11:49 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
