T56 parts needed
Old Jun 30, 2008 | 03:04 AM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
T56 parts needed
Looking for LT1 style front plate with input shaft bearing race, input shaft with bearing, main shaft with front bearing, 1-2 gear stack without slider/syncros, but with the 1-2 syncro hub, rear main shaft bearing, and a main case.
I need these parts as a setup for testing my T56 cable drive speedometer conversion for proper gear tooth engagement. So, gears don't need to be good, input and 1-2 can have all the teeth gone. I just need enough of the trans to hold the main shaft in place and have it rotate . I'm using my own T56 for testing the speedo cable mods and I'd really like to put the trans in my car like was originally intended.
midge54
Jan 29, 2017 07:00 PM
IROCZ1989
Jan 24, 2016 03:55 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
1nastygta
Aug 8, 2015 07:38 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
